- Joined
- 27 Jan 2008
- Messages
- 27,755
- Reaction score
- 3,364
- Location
- Country
What is the "suitable meter"? It seems you can refuse a smart meter, and if you do, what you pay is your problem, likely a fixed tariff, but there are also people in locations where smart meters don't work, that is completely different.BBC said:If your energy supplier cannot fit a smart meter in your home, Ofgem says your supplier must install a "suitable meter", with no disruption to your service.
My smart meter works, so does not affect me, but as 30th June gets closer, people will need to find a workaround. There is a North/South divide, Liverpool to hull, in the North the radio signal is in the control of the supply network, and they could use the mobile phone network. The South is more of a problem, as there is only the mobile phone network.
As to the use of a quartz clock of some type, checked by the meter reader when he visits, the only problem I see, is slight variation in user's time clocks and suppliers time clocks, I had this with an EV supply where seemed to be some uncertainty as to if using BST or UTC in the summer. So although 00:00 to 05:00 I started using it at 01:00 just in case.
I could charge my battery in 1.5 hours, real EV users would be different, they likely need the full 5 hours, and storage heater users have always had a problem with 7 hours, and we have seen it split 6 + 1 with one hour some time in the day, and economy 10.
But I can see this question arising many times between now and the 30th June, specially in Wales, Cwm Brefi only got national grid in 2003, and car radio stops working many times as we travel through Wales, and mobile phone can't be relied on, I use PMR466 in some areas, even England, went to the Beamish Museum and found my mobile did not work, and not really that many hills around there.
So what will happen?
