Some of the existing pipework is solvent-weld, which you can’t change (except for cutting it).
I would avoid using a flexi; use pipe and elbows. I always worry about whether the screw fittings will fit to the solvent-weld pipe, which may have a slightly different diameter. I’m sure someone else will know for sure.
