Old chrome trap was crumbling; I'll replace with plastic. Previously, the chrome pipe (approx 30mm diameter) leading into the wall went into the wall pipe you see in photo (approx 34mm). I have 32mm pipe but it's too big to go inside wall pipe and too small to put the chrome pipe into (I thought about using it as bridge). The wall-chrome pipe section was also leaking so that wasn't very good anyway.
What are my options other than ripping out the pipe in the wall and installing new joints and pipe outside on the other side of the wall outside? The wall pipe is nearly flush and there isn't much space around the pipe but I am thinking of using one of the joining solutions below, but I fear the wall pipe will be too big as its diameter is slightly more than 32mm?
