Hello all
Slightly odd situation of our house having a garden which is about 25m from the back door. We have to walk down a 15m pathway (covered in centuries old york stone slabs, cross our driveway and then down another 5m pathway next to our garage before we get to the start of the garden.
So the problem then is getting a tap put in. Currently I have a 25 quid tap in the basement which is taking a feed from the supply to the washing machine - one of the ones which just taps into the water feed, so a very narrow pipe feeding the tap. This coming from the main house supply plus running a 40-50m hose off it means the pressure by the time it reaches the garden is pretty pathetic.
The solution I'm considering is a separate feed from the mains using MDPE to a dedicated outside tap, which I understand being for the garden can have higher pressure. The problem I have is getting the feed down to the garden, which would be down the 15m pathway, under the driveway and then back up at the other side, into and through the garage.
I have already dug a channel under the driveway which is about 40cm deep as I was doing this already for an electrical supply to the garage and the building next to it. However, the 15m run from the house to the driveway I really can't get underground because of the york stones I mentioned earlier. There is no way I'm taking them up and also even if I did, no way I'm digging another channel 15m long underneath them!
So the clear challenge is the pipe freezing. It is a slight gradient away from the house down to the driveway, then under the driveway will clearly be the low point before it comes back up and then through the garage. If we were to turn off the supply in October/November before any frosts come, could we drain the MDPE so it's safe from freezing? Would the low bit under the drive cause the biggest problem? If so, I was considering putting some sort of "trace heating cable in the ground with the MDPE under the driveway (like this https://www.traceheatinguk.co.uk/premade-trace-heating-kits-thermostat )
Any thoughts and help would be much appreciated.
