@Bertie78 Just a thought - can you take apart both of them and swap the internal carbon beads.
Actually should be a thing to be able to buy spare bags of carbon.
I tried something like that, it was a nightmare.
I don't think that 'changes in cooking methods' has resulted in much reduction in 'cooking smells', which is one of the primary reasons for extractor hoods..... But the pan with fat for cooking chips gave way to the self-contained unit, which has in turn been replaced with the air fryer, so changes in cooking methods has made the extractor redundant.
In passing (since you mention them) I really don' understand why "air fryers" are called "air fryers", or why there is so much interest/excitement related to them - they are surely just small fan ovens, nothing more, nothing less, aren't they?
Well, whether you call it "frying" or not, there's really nothing one can't do in a 'big' (standard size) fan oven that one can do a small fan oven (these days known as "air fryers").Do you fry chips (and other things) in an oven?
Well, I think you have to in this context.Well, whether you call it "frying" or not,
Yes, we do - well, to be more accurate (since I'm not sure that 'frying' is really the correct word), we create 'chips' in the oven in the same way as we do (or can do) in our 'air fryer' - just toss the cut-up potatoes with a tiny amount of oil and then cook them in a dish in the oven OR cook them in an air fryer.Well, I think you have to in this context. I ask again: do you fry chips in an oven?
As above, that question is "Not Applicable"If not, why not?
On recirculate the idea is that the carbon granules filter the smells and the aluminium grid on the underneath of the hood catch the grease. Some built in hoods where you pull out the faux door use a big paper grease filter.We do have a cooker hood which does extract, very rare turned on, use the lights, but very rare the fan is turned on, I am sure house has never had gas cooker, we don't have gas, so the idea of blowing air through a carbon filter not really sure what it does? Or how to measure how effective it is? What would worry me is a load of fat above a hot stove. But the pan with fat for cooking chips gave way to the self-contained unit, which has in turn been replaced with the air fryer, so changes in cooking methods has made the extractor redundant.
"Cooking" and "Creating" are obviously very general/generic terms. As for frying, I think most people take that to refer to cooking things in a significant amount of hot fat/oil, whether 'shallow frying' or 'deep frying', such that it is the high temp of the fat/oil that does the 'cooking' of the food. That's why I'm hesitant to describe what one does in an "air fryer" (or the equivalent in a fan oven of any size) as 'frying', since it involves little or no fat/oil, the cooking being done by circulating hot air.Perhaps it would help if we found out what the difference is between 'frying' and 'cooking' or 'creating'.
Well, for a start, as I said, an Aga is not even a 'fan oven' - it's just a regular non-fan oven. However, as above, if the cooking one does in it is not done by hot fat/oil, I'm far from convinced that it is correct, or sensible, to call it "frying".If you are making your aga into a huge air-fryer then both presumably achieve the desired result without a large pan of molten lard or cooking oil on the hob.
Yep straight outside is perfect. And as little amount of bends as possible I have to go 2M with 2 bends. I recently went from the flat oblong pipe 100x50 to 100x100 round and that in itself has made a big difference to the extraction rate.My multi burner gas hob has a outside vented cooker hood directly above fixed at the height indicated in the hob instructions. The hood is used every time a burner is lit and it has certainly helped in keeping the kitchen decs clean and grease free. To ensure max efficiency I removed the filters when it was fixed some 12 or so yrs ago and I've been very pleased with the purchase. Personally, I cannot really see the point of an unvented hood as smells/fumes/ combustion products are simply wafted around the kitchen to contaminate the decs.
AgreedYep straight outside is perfect. And as little amount of bends as possible I have to go 2M with 2 bends. I recently went from the flat oblong pipe 100x50 to 100x100 round and that in itself has made a big difference to the extraction rate.
Then again the need to extract depending on the kind of cooking you do - its always good to extract steam but when you are searing stuff and doing chefy things then its not just about steam.
Yes wok cooking does kick up a lot of stuff that needs extraction.AgreedI tend to like wok cooked food which does create steam and plenty of combustion products. I also like well boiled spuds to mash with lashings of butter, although much to the disgust of my consulting cardiologist. . . . sorry, Nick, get over it cos I like what I like
