- Joined
- 10 Jul 2025
- Messages
- 7
- Reaction score
- 4
- Country
Dear Community,
My very elderly parents have a Potterton Promax Combi HE Plus boiler. It is under breakdown maintenance with British Gas to which each fault claim attract an excess fee.
With that assurance of breakdown in mind, we have been having an ongoing issue with the boiler, one which BG seem not to be able to fix.
The issue - when using HW is finished, and there is no further demand for HW, the fan/pump should switch off. It doesn't for period of 15-mins, 30-mins, 1hr. There is no fixed pattern.
When BG came they have never heard of this issue before and changed divertor valve and motor which sits on top of divertor value. Since then I have been monitoring, and the problem is still there.
Sometimes, at 2am in the morning, when no in the property would be using HW, the boiler fan/pump is still running.
The temp gauge on front can read 86-87 degrees and the TAP LED is ON.
I am at a loss why this is happening and for fan/pump to keep running suggests there is still an underlying fault. It cannot be right that fan/pump doesn't switch off after 5-mins or less of last call for heat.
Because it is at my elderly parents home, they would not know what the boiler is doing.
In light of the issue still being apparent, I am going to get BG back in again on the basis of original fault still existing.
Reason of posting it here, would be to see if any expert in this community could suggest what I can tell BG to check when they come back. I know, they should be telling what the issue is, and fix it, but right now that is the concern.
Any help would greatly be welcomed.
Thank you sincerely,
Red.
Red.
