Extension footing - how to make this look pleasant
4 Feb 2017
East Anglia, England
Hi all
I have an old extension, 60s house, 70s suspected extension. I think it is on a 'raft' foundation. You can easily dig under this 'footing' all around the extension and it isn't very deep. It's about a brick thick, and it starts one brick below the house DPC.
I aim to do a patio around this that ends at the top of the footing so it is all contained. It is unfortunate that it will be one brick below DPC but I don't have much choice in the matter here.
The top of the 'footing' is flat on two sides but on one side, it has had mortar and concrete poured onto it, I think from a previous path. This was all bobbly and different heights, so I've ground that down to remove the unsightly vertical protrusions. I ground this down figuring this is the least destructive method, with the least risk to the concrete footing below.
My plan is to 'haunch' on top of this concrete footing/the ground down surface on top of it- basically put a triangle of mortar along its length so that water that falls into it is directed into the ground, and it is more sightly than unfinished concrete.
As I ground down I found gaps in the cement where dirt and moisture has got in. I was planning to 'haunch' over the top but I'm not sure if I should remove all this concrete mess on top to get rid of all moisture first.
My plan is to use SBR along the top of what is there, and the visible brick on the wall.. mortar mix and cover the vertical bricks so the rendering is complete as currently it is all wobbly and bricks show through; I suspect when this was done, someone rendered down to the dirt/stones! Once that is done I will do my triangle of 'haunch' along its length. I'm not sure whether to use Thomson's Water Seal before I apply any mortar, after, or perhaps both, to be belt and braces against any water ingress.
Hopefully photos and diagrams will illustrate what I mean- what do you think? My main concern is - should I remove all the old mortar on top of the footing first, shall I apply water seal before applying any mortar?
I'm not clear on why you aren't just laying the patio over it ?
If I did that it would raise the ground level further towards the DPC - it would probably end about 1 inch below it at the house. I'm trying to keep it as low as possible
Patio needs sub base; I could perhaps put a mortar bed onto this footing but again.. 50mm mortar + 20mm slab probably would make the ground level meet the DPC of the house
Cut the corner of the found off (so it's sloped like your launching, but lower) and lay the patio over it ?
So I’m looking to continue with this. All the crappy mortar is chipped off now leaving me with the bare footing
My plan is to
- sbr slurry to the bare brick
- mortar mix, ratio TBD, to this area
- smooth it out and make good.
Intend to keep it breathable as it’s so low and it will get wet when rained on. I then am going to do the haunch described above so water is shed away from wall and footing.
Any opinions on this approach? The render is to this level on the other two walls, only this one differs. Suspect ground used to be higher here and they rendered up to the ground and no further!
