Hi there.
I've just had a new shower fitted, a 'Mira Extra', which (I think) is a thermostatic one, i.e. it adjusts the hot and cold flow to get the set temperature.
I've got a combi boiler (a Halstead Finest Gold) which the brochure says is a modulating boiler (i.e. one which reduces the gas flow when the hot water flow is reduced, so you shouldn't get a spike in temp when turning down a hot tap).
As far as I understand things, this should all work. However, the problem is that the shower drops the pressure down to a trickle over a minute or two, exactly as if it was pulling less and less water from the hot.
By turning the sink taps (when the shower isn't running) I notice that the hot water temp does vary a lot - the water is very hot when it's a trickle, which would I guess explain why the thermostatic shower is having trouble keeping up. Does this mean the boiler is playing up? Do they 'stop modulating' over time?
Do you think it's worth playing around with the different settings (hot water temp from boiler, thermostatic setting on shower, anything else?) or should I try and get the shower replaced with a manual? Is there anything obvious to check on the boiler? (pressure gauge etc?)
The shower starts off great (good pressure and temp) but then the pressure dies away, presumably as the thermostatic valve fights the boiler
Lastly, should I be asking this in a different part of the forum?
Thanks in advance for any ideas or suggestions.
