Hi
I've been working at friends house to try and fix up some modern(ish) doors/windows that are double glazed with the glass held in by wooden beads. What seems to have happened is that the beads are just no good (unlike putty windows) at keeping the water out. As a consequence, water seems to have soaked down into the wood below, worst on the door which has totally rotted out and is basically scrap although I will probably bodge it up for now. Have to say unlike traditional putty this system seems useless !
My plan for now is to devise some sort of system to set the bottom bead in some type of mastic to completely seal it, leaving some little drain holes above so water running down can run off doesn't get trapped.
Any thoughts from those who have dealt with similar problems I'm very interested to hear.
I picked up on the offchance some window bead in Wickes ('Cheshire Mouldings') which is almost correct for the window, it's just too deep. I could (but don't fancy) cutting it down lengthways but if anyone knows a good stockist of these profiles I'd be interested to hear.
Thankyou !
Thankyou !
