I'm a free holder, owner occupier, of a top floor flat, split level (two attics), in an old building. There is work needs doing on a chimney stack that is causing water damage (main attic which is ~40sq m) and there is a problem with water ingress from the flashing above the lower attic (above bathroom ~6sq m of level floor with a section that slopes down as well) when wind drives rain against the back of the building. These issues will likely not be fixed until next spring and I mention them as it may affect what is the best course of action to get at least some insulation between the joists for this winter. Currently there is none.
As I think that more than 10 photos (maximum per post) are required I will upload 9 of the rear attic in this post and others later.
So these are 9 images of the little rear attic. As you can see there is an old metal water tank up there. I can't get rid of it, someone brought in an angle grinder but couldn't do it. It's worth noting at this point that I have a sparky coming in soon to rewire the lighting circuit (there is currently no earth) and have told him to set up the cabling so I can insulate it without the cables being a problem. So, my thoughts are to clear the debris that is up there and then poor loose fill insulation between the joists which are 29-32cm apart (inc inside and under the water tanks) before laying something like Thermafleece CosyWool perpendicular over the top . So then I need some sort of baffle to prevent the loose fill pouring down the slope but I'm unsure of how to approach doing that. Plus I don't know how to deal with the small area close to where the attic joins the back wall. Plus what is the best way to insulate the slope part? The beams that go down over the slope are 100cm so that gap is a little less. I hope I've explained myself well enough and will upload main attic pics in the near future.
