Toilet brush holder replacement
10 Nov 2023
Hello all,
I need to replace the wall mounted toiler brush holder. The brackets in the wall are in the picture attached. Any ideas how to find compatible types? Thanks.
Just thought I'd mention although not answering your question.
Using existing holes in walk drill through the holder.
You can then use chrome or stainless caped screws.
Won't really notice the screws if you can find a matching fixing at DIY store.
I've done that a few times as those mounts can be a problem
Any with a concealed fixing plate , you will likely need to replace that one for one supplied with holder as there are many variations,
I can recommend the Silicone wall mounted brush. I’d comes with a strong double sided mount. Doesn’t take up much space, looks good and is hygienic.
