Sorry, I'm very much an amateur here, I'll try get my plumber around next week to do this but can you put this in idiot terms for me and tell me what that is and how to check it?!
Probably need your plumber (make sure he is G3 certified if working on the UV cylinder).
You need to be able to isolate the hot supply to the system and then see if water continues to run from a hot tap after 10 mins or so.
This would indicate that a NRV in a thermostatic mixer has failed and cold water is crossing over and flowing down the hot pipe which can cause blending of hot and cold at other outlets, thus giving you tepid or cold water, if the pressure difference is great enough.
