bit confused.
10mm2 cable runs from consumer unit (32Amp MCB) all the way through to cooker outlet plate (via cooker control unit).
New induction hob is supplied with 5 core cable (2L2N1E), which apparently has 1.5mm2 conductors (has 5G1.5mm2 on cable), to be connected to the outlet plate.
Hob is rated 7.4kW.
Cooker outlet plate info says use conductors of same c.s.a (CSA cross-sectional area).
So how does that work, if the hob cable to use has conductors with much less CSA than the supply cable coming into the outlet plate?
Thanks,
bit confused.
Hob is rated 7.4kW.
Thanks,
