Two way light switch issue
7 Dec 2025
Hi, I have a lighting issue that I’d be really grateful for your advice on. I have a ceiling light in my living room that can be switched on or off by one gang, two-way switches located near the two doors, one to the kitchen, and one to the hall.
I removed the old metal faceplates today and replaced them with plastic one gang, two- way switches, connecting them exactly as before.
The switch by the hall door contains a three core and earth cable and is wired as follows:
Yellow to COM
Blue to L1
Red to L2
Green/yellow to earth
The switch by the kitchen door contains three cables and is wired as follows:
1x Yellow to COM
1x blue plus 1x black to L1
3 (not 2) x red to L2
4x green/yellow to earth
I have two questions:
  • One of the cables to the kitchen door switch only contains red and earth wires (no black). Could you tell me why there’s no black? I think there may be one but might have been cut off by the previous owner. I can’t see it; maybe it’s tucked away in the outer sleeving. Also, I don’t understand what this cable is for – I was expecting just two (not three) cables in this switch; one twin and earth and one three-core and earth. No other lights are controlled by this switch.
  • Despite being wired exactly as before, it doesn’t work properly, in that both hall door and kitchen door switches can turn the light off, but only one of them can switch the light on. My first thought was that the new switches were faulty, but I have tried swapping them for spares and they still don’t work.
If anybody could help with either question I’d be very grateful! Many thanks in advance.
Single-and-earth wires are available. They aren't often used.
My guess is that it is supplying a permanent live to something else that we don't know about. There are other possibilities. If you disconnect it, you may discover what no longer works.
You haven't wired it exactly as before.
Any pictures of the actual connections?
I did try to take photos but unfortunately the wires inside are short so couldn't pull the faceplate far enough away to take a clear shot. I'll try taking them apart and putting them back together again when I've got natural light tomorrow morning. Thanks for your reply.
Thanks for your reply. I'll try taking them apart and putting them back together again tomorrow. Also I'll try disconnecting the single and earth to see what happens, as you suggest. Cheers, I'll let you know how it goes.
Afternoon all, this morning I disconnected and reconnected both switches (same way as before) and they're working fine now. No idea why; maybe there was a loose connection first time round. I decided to quit while I'm ahead and not investigate what the extra cable does! It's been there since before we moved here, nearly 20 years ago, so I'll let sleeping dogs lie.
Many thanks for all your replies and suggestions, much appreciated.
Cheers and have a good Christmas if it's not too early to say that!
