How to do washing using off-peak?
27 Jan 2008
Llanfair Caereinion, Nr Welshpool
The washing machine has a delay start timer, as does the tumble drier and dishwasher, the tumble drier and washing machine, both tumble the clothes every so often while waiting for the start time, this is not a problem with the tumble drier, but with the washing machine, it means the soap in the ball is tipped onto clothes before the wash cycle starts. Put the liquid soap in the draw, and it runs through again before the cycle starts, only option seems to be use washing power, which is not really what we want.
Result is rarely use washing machine on delay start, but this time of year not much solar, so don't want to run during the day, ideas please.
Nowt like that here, we just do a wash as and when needed, but check the price for the day, to see if it might be better to delay a day of two (Tracker tariff). Same price, for the full 24 hours.
Today, for instance, Av asked me to check whether it was a cheap day, or an expensive one - today it is 22.62, tomorrow 20.60p per unit, so the wash gets delayed until tomorrow. If we more urgently need to use it, we generally do ignore the cost, unless the cost, as it rarely does, rises above the SVT.
In summer, hardly matters, costs 8.5p/kWh at night, and we lose export payment of 15p/kWh in the day, but winter 30.51p/kWh in the day is quite a bit more than the 8.5p/kWh at night.
November my bill was £61 and a bit, summer the bill is in the minus, not a massive bill, but don't want to spend when not required.
Electric, £55, and gas £78, inc standing charges for the entire month of November. That's heating on constantly at 14C, and 18C during the day, no solar, no storage, no EV.
It's not much cheaper, the electric use in summer it was £53 in June, but gas use was down to £22.
My oil is lasting a lot better after I stopped using it to heat DHW in the summer, can't stop it heating DHW in the winter, I use around 12 kWh per day, so working with this 1765640553462.png £130.73 actually last month, for electric, down to £83.61 if I take the solar off, so the off-peak is saving me money, bringing it down to £61 for the month, I did look carefully at the tariffs, as easy to end up paying more, if not using enough overnight. A bit up last month to 14.5 kWh per day, normally around 12 kWh per day. Unless running the AC which clearly not needed this time of year.
But having a shower at 1 am is not something I intend to do, there are not many things one can move to off-peak, as to doing an Angela Rippon and doing gardening at night, think my neighbours may complain. So in real life only really the washing which can be done at night.
What brand / model washer does that? Seems a pretty daft idea to move dirty (dry) clothes in a drum during the wait to start. You could replace it with a new Miele TwinDos washer that dispenses the liquid(s) from containers held inside the machine at the correct time in the cycle? Not that I've ever set a delay start on my washers over the years, ever so can't be sure what would happens on them if delayed. Mine does have an anti-crease feature at the end of some wash cycles... but that stops after a time and it switches off.
Does the liquid soap in drawer actually reach the clothes in drum, and not just go to the bottom of drum to be diluted when the water enters later?
Or just stop being so mean and run the machine during the day. Life's too short to be such a Scrooge. ;)
(Surely the uber-expensive battery you have is intended for this very purpose of delivering off peak energy to appliances during peak periods. Increase the capacity if inadequate for this purpose.)
The what?
Surely the idea of pouring liquid slop into a plastic deal and balancing it on top of clothes hoping it didn't spill and destroy the item directly below was a short lived novelty that went away several decades ago?
It does not matter what I think, SWMBO wants to use the liquid soap, and years of using power soap which stays in lumps, so ends up in the rinse water as well as the wash water I can see her point about trying to ensure all soap power is removed before rinsing starts.
As you point out a new washing machine, or an extra battery is not really the answer, as both cost too much, the washing machine I bought I was told was useless, so from now on she selects washing machines.
I have looked at the balcony solar kits, and the portable battery packs used with them, and they do have a lot going for them, as multipurpose, allowing me to use it for more than just power the house, but for the short time in the year when I don't have enough battery capacity it's using a sledgehammer to crack a nut.
But sometimes one misses some easy, cheap method, so worth asking the question.
The cost of such an overpriced machine would be decades of savings from using off peak electricity.
You can not think I was being serious and Eric is far too Scrooge-like to fall for it. ;)
There are three brands that do similar dosing systems but I've not looked at the price.
Dissolvable liquid capsules/pods instead of the ball? https://www.bmstores.co.uk/products/household-and-cleaning/laundry/washing-pods
Other retailers are available.
Or just use peak rate electric until the washer is replaced with one that doesn't jiggle the washing when set on a timer delay.
Doesn't matter one bit if liquid detergent spills on clothes before the wash starts, I pour the right dose directly on top of the clothes and then start the wash or set a delay timer as needed, never had an issue with clothes staining from detergent or anything like that. Don't like using the draw either as it makes a mess of it
I must talk to wife over pods, but think an energy monitor on the washing machine is needed, how much is saved washing overnight, is it worth the effort? 30.51-8.50=22p/kWh saving in winter, does a wash use even 1 kWh?
FWIW my Miele TwinDos washer is "smart" and has a 'report' that says we've done 16 cycles this month... 5.5 kWh in total and 342 litres of water.
9 in October: 3.3 kWh, 226 litres
19 September: 4.4 kWh, 336 litres.
17 August: 4.0 kWh, 340 litres.
The Year total has 202 cycles, 47.4 kWh and 3, 432 litres of water. (That's an average of 235 Watts per load :love: ). Mostly we do low temp 30C or 40C washes. Some short. Some woolen/handwash cycles. Occasional hot 60C or even a clean the drum 90 when prompted (no clothes, detergent powder in drum).
Note the water's colder this month so using more electric (and the last wash was a 60C towels, short one).
So for me on my current EV tariff 27.02p day, 6.7p night:
Washing clothes for a year has cost £12.81 day in electric and could have been only £3.18 if we wanted our sleep disrupted by the washer water running and hammer noises.
Your costs will vary as your washer may be more/less efficient and wash load types will not be the same.
In the past, been surprised how little it costs to wash clothes, it is the drying which costs, your £10 per year will mean just a few p per wash, so seems not worth the bother even measuring.
The drier at 600 watt for a few hours, yes worth waiting for the off-peak.
