Is this a good solution for parquet dilemma?
12 Dec 2014
Birmingham
I’m putting parquet all through my downstairs, but I have a 3mm lip where the suspended timber floor buts up against the concrete slab in the kitchen (put in during previous extension).
I thought about simply putting down a metre of 3.6mm plywood in front of the lip and feathering it via sanding. Would that work?
Seems a lot cheaper, easier and sturdier than levelling compound.
I think it's a lot more work than shaping something cementitious in though, as you'll want to run quite a way to avoid having to do a considerable amount of sanding to smooth out any kick in the parquet ?
Is the concrete 3mm high? if so could you not grind it lower, or if its the floorboards could you remove a few rows, and replace with thinner boards, packed where needed?
Long as you can be bothered with, I'd say. 60cm doesn't seem unreasonable unless the parquet blocks are large.
If you end up with an obvious kick anywhere in the parquet and the adhesive you're using has some flex maybe also consider (part-)bedding the transition ones on a harder adhesive, like gripfill, that way you remove a potential movement point
Kissinger, can you draw us a diagram of what you're trying to do. It seems everyone is coming away with a different impression of your task
I wouldn’t use parquet in a kitchen. Worst case, find a laminate/LVT that closely matches the parquet.
Granted, I was using reclaimed parquet, and had access to the equipment but…
Could you get access to a thicknesser?
I used reclaimed parquet (25mm teak) and removed all the old bitumen adhesive before running both sides through a thicknesser/planer .
I would imagine that making a batch of your blocks 3mm thinner wouldn’t be too hard?
I don’t know if you are using new or reclaimed blocks but if used, it’s fairly essential that you clean the blocks to within an inch of their lives.
