Screwfix Prices Then And Now
11 Jan 2004
I've been using Screwfix for decades, since before there were shops.
Since around 1993 I've been ordering via SF Direct and getting deliveries.
I am doing a load of tidying up and found a catalogue dating back to Spring 1999.
Some of the prices are as follows:
1999
Turboflush macerator. 775W. 3m vertical 40m horizontal £240.
2025
550W. 3.5m V and 45m H. £285.
So, down on wattage, but slightly improved performance.
1999
SF own brand Can't Believe It's Not Nails
310ml. £2.29
2025
No Nonsense CBINN
280-290ml. £4.49-£8.99
1999
Workbench. 9.4kg weight, 100kg load £13.99
2025
4.9kg weight, 100kg load £29.97. Smaller dimensions all round.
1999
Gold screws 4.0 x 50 £2.54 per 200
2025
4.0 x 50 £4.29 per 200
And unless I am completely misunderstanding the last price comparison, in the 1999 catalogue were 12 ga x 2 ½" brass slotted wood screws at £11.71 for 200.
In the current catalogue are Timco brass slotted wood screws 12 ga x 2 ½" listed at £93.89 for 100, part number 523KF.
Perhaps in the last 25 years demand for slotted screws has dropped massively with the ubiquity of cheap, good cordless drivers demanding pozi headed variants and they've moved out of mainstream "goldscrew" grade availability and into specialist manufacture from more expensive brands
1999
2025
1999
310ml. £2.29
2025
No Nonsense CBINN
1999
2025
1999
2025
I can remember when screwfix used to have an advert in a woodworking magazine, they literally just sold screws and nuts and bolts.
That would’ve been around 1980
I'm now getting to an age where I'd be just as happy, maybe more so, looking through a Screwfix or Toolstation catalogue as opposed to a p0rn mag :)
And yes, I know p0rn is mostly online these days (or so I'm told ;)) but I used the mag reference to keep things in context.
Two tubes of CT1 a few weeks back from toolstation, 28 quid, needed more so looked at screwfix, they've stopped doing CT1 and do something called OB1 for a bit less, ended up getting the OB1 on Amazon for £9.99 a tube.
I know you can get deals for a case of 12 but I don't want 12.
Someone has to pay for all those welfare scroungers!
Sika Stixall is good. 7.49.
Ironically I’ve been searching for slotted, curved stainless screws today. No4 is the size I’ve punted for. 10p each I think
Imagine if all we'd had had been pozi or torx, etc screws "for ever", and then someone invented slotted.
How successful do you think they'd be?
I don't buy a lot from Screwfix, but recently bought a new radiator, as one of ours had developed a pin-hole leak. I hadn't initially realised that ours, probably all of them, are traditional imperial sizes, so I had to order a lightly smaller metric replacement. No problem, as the plumber obtained a extension connector. I found their prices are very reasonable and delivery quick.
As for screws, I am sold on Torx now. They never cam out, unlike posidriv, and are just as easy to use and better than slotted screws.
I used to find Screwfix shockingly cheap, back when it was an independent business.
I suspect a lot of the price hikes were after the B&Q takeover.
Then the original owner started up Toolstation, which was then sold to Wickes.
There are basically two companies that run the whole lot. They don't compete, they mostly just match each other's prices.
Pozi don't cam out either, unless the bit is shagged from being rattled around inside umpteen screw heads due to poor screwing alignment, insufficient pressure, inappropriate driver speed, over counter sinking or using Pozi bits in Phillips screws/screws that are supposed to be driven by the next size up..
Keep a stock of PZ2 bits and swap em out if they've bounced around inside too many screws or look visibly propellered
That said I do think Torx look the nicest of the lot, I'm just too cheap to buy them when PZ work so well for the price, and if I'm laying out big money on screws it's turbo coach screws every time; they're beyond compare for everything apart from aesthetic
Pozidriv is designed to cam out. It's a feature.
Not so; I think you may be confusing Pozi and Phillips. Phillips are designed to cam out because they have angled sides and are found in industrial application where a machine is driving the screw, so pressure and angle are consistent and the robot needs the screw to separate easily from the bit when it's done driving
Pozi have straight sides (parallel driving surfaces) and do not cam out unless ruined or driven incorrectly. They're found in manual/human processes where the greater torque afforded by the straight side is more beneficial to the performance of the fixing.
The only place in a typical build process one would find a Phillips head is in plasterboard screws, as it well suits the lower torque and mechanised installation (screw gun mechs that sink to a depth and then let go of the screw). In most other construction applications Pozi is the head of choice
