How to set the door opening size in timber stud walls.
26 Sep 2025
Self build getting to the stage of installing some internal stud walls on block and beam floors. My plan is to lay a single row of concrete blocks then build the stud walls off that so it gives a solid base and allows me to get on with building the walls before the screed is in.
Taking one of the walls which will have a double door as an example, this post is really to check my thinking about how to set the door opening sizes correctly.
One door size = 27 inches/ 686mm
Two doors will be 53 inches/ 1371mm
Two legs of door lining around 50-55mm + 5-10mm allowance
Therefore two doors + door lining (with allowance) = 1371 + 60 = 1431mm
Have I missed anything?
Assume I should leave a bit more tolerance for door frame height given I don't know the finished floor levels yet?
Check the dimensions of timber you wish to use are available. Or better still purchase now and be sure .
Yes the timber is available. I know it's advisable to get it now to be able to do actual measurements but we're getting the whole of the ground floor screeded at once so trying to keep floor space clear - which is a bigger challenge than it sounds!
I'm thinking I should leave openings a little bigger if anything so that packers can be used if required. Far easier than having to move timbers/ noggins.
