- Joined
- 25 Nov 2025
- Messages
- 32
- Reaction score
- 4
- Country
Another day another question. Thanks for all the advice I've received so far from everyone. This weekend is going to be my big plumb up; think I have everything in place to get started now!
Before I finally commit, I just had a couple more questions if you kind folk would be so kind to share your expertise on. The below is a portion of how I'm intending on reconnecting up C/H system. The vent and feed (apologies for my likely butchering of terminology) are in the same logical place as it was before I began the renovation, but the actual runs of pipe are different. I wanted to check that I won't have any problems with this, as I've read that the pump can sometimes pull air down the vent pipe and into the system; it didn't seem to happen before (or at least I didn't notice if it did), so I'm assuming this is still an acceptable way to plumb it? I've read about tying the vent and feed pipes together, but the specifics of the 150mm rule aren't clear to me, or whether I actually should tie them together at all?
The only other question I have is around the specific levels/measurements I need to adhere to around the crook at the top of the vent pipe?
Other than that, any other general comments are always appreciated!
