Help advise process to replace hinges
  • Thread starter Thread starter ih
  • Start date Start date
ih
4 Nov 2006
London
Hi intend to replace porch uPVC 4 door hinges million dollar question will it require for the door to come off completely?? Need idiot's guide
Thanking in advance for help & advise
Hmmm generally yes but you could do one at a time, but you'll need to remove the door half of the hinge in order to expose the 3 screws holding the frame half of the hinge on
  • Thanks
Reactions: ih
Being poor diy'er will have to re read your instructions few times does the door comes out with glass or does glass is removed then
Door frame is out ( assuming glass is the real weight imo)
Why do you think they require replacement ?
Couple of hinges are not in slot & it is restricting easy door movements concerned of failure I wonder if tightening the hinges with Allen key
Will solve the problem??( Couple of hinges have risen up from the hinge slot) More photos attached
