Yeah plenty of 40/45 on eBay without tab.
They are to prevent the coloured part being fitted into a way that s not rated for 45A
I did that in 2005, it's still sat in a cupboard while I continue to use an older fuse board than the OP'sMaybe time to save up for a new CU
It's getting confusing (at least for me)! Not only have I been looking for a tab that everyone had been calling a notch, but I've also been looking at the MCBs themselves, not the 'base'.Yeah plenty of 40/45 on eBay without tab.
I don't think you can really blame me. This all started when I read the quote from flameport which read ...No wonder you are confused !
... which is why I had been looking at the devices (rather than bases), and looking for a notch (rather than tab).... Devices over 30A have a notch which fits into this cutout ...
I'd have to look to see what lines up BUT no that board is not designed to take a 45A device.So this one will accept a 45a next to the main switch only. Assuming coloured part has a tab.
Can you see how???!!! Probably not
What makes you say that - the position next to the switch looks no different from any of the others to me!So this one will accept a 45a next to the main switch only. Assuming coloured part has a tab.
See aboveCan you see how???!!! Probably not
OK had another look and as already been said the notch is there and indeed the contacts are a different colour.I'd have to look to see what lines up BUT no that board is not designed to take a 45A device.
The cable entry holes are a lot smaller on the 30A ways though.Copper as thick as what was in those wylex boards can easily take 40 amps.
Too small for a 6mm?The cable entry holes are a lot smaller on the 30A ways though.
