Get rid of all the grey pipe fittings, push fit couplers are terrible things, replace the connection up to the sink trap too.
As suggested replace it all with solvent weld (SW), apart from the final connection that drops into the floor, that will need to be compression and fit a proper standpipe with trap where the current drain hose is fitted into. If SW is beyond you then replace the couplers with McAlpine compression fittings.
Do you know what's under the bottom shelf as far as connections are concerned, if that's the same push fit then there may be trouble lurking under there too.
