Hi. I wondered if anyone could provide some insight into what option is best to reduce internal wall damp and mould due to cold walls.
For context, weve been living in a 1930s semi detached property for almost 7 years and throughout this time weve had some mould issues on several walls in the house which come about every year in the cold months. Weve fitted a PIV unit a couple of years ago and thats helped with ventilation and reducing condensation but some parts of walls still get damp and mould build up. We had a company come round to assess what can be done and theyve suggested a coating of Stormdry Masonry Protection Cream around the external walls (after the cracks, holes and gaps have been repointed and the wall has been cleaned), as they say this will provide help seal any gaps and provide some insulation and warm the internal walls. Our external walls currently are a mix of brick and painted and exposed pebbledashing, so not a consistent look. So whilst the StormDry option seems like a potention solution, my concern is that (even with the relevant tidying up and repointing) the StormDry will be sprayed over uneven surfaces and not look smooth. The other option we were thinking about was rendering the outside as this would give a smoother neater finish but were advised against this by the company as they said it wouldnt be breathable and would trap any existing moisture. Having done some research it seems lime render is breathable, more flexible and does help with providing some insulation.
So my question is, does anyone have any experience of using either the StormDry cream or having lime render used as a solution to internal wall damp and if so, which would be the most suitable option? If anyone has put in lime render, is it known to be breathable and has it stopped any internal wall damp/mould? Interested to hear peoples thoughts and experiences.
Thanks in advance
Thanks in advance
