Bosch easycontrol ct200 smart thermostat advice please
13 Apr 2011
Antrim
I just got a brand new heating system its worchesr bosch greenstar 4000 and it came with the bosch easycontrol ct200 thermostat. So first day the rads where warm but not what i expected and i thought fare enough it just needs some tweeks on the flow valves. Second day slightly warmer and i thought okay it will balance out. But today i am not convinced. I tested by turning the temp from 20c to 23c on app and it only crept up to 21 and wont climg any higher. Its not cold out yet it still wont climb. So i am thinking if its -1 out what will it even reach. I think i have the app set correctly. Has anyone any experience with this app?
Try turning it up to it's maximum setting, to see if the radiators then get really hot. That system is a clever system, which is designed to run the radiators just hot enough to meet the demand on it. The radiators should become hotter, when there is a greater demand.
So i have the temp set so at 730am the house is 20 degrees with the optimal heating it came on at 6.58am and at 735am it had still not reached 20 degrees. Now i know its only one degree out but i like things to do as thry say on the tin.
