it cracked he end off at 45 degrees so doesnt really help unless I take the full tile out, bit worried I may not get it back in again without a full tile at the ready I might do more damage
You might need a gadget, to lift the tile up enough to unhook it. I made a bit of flat steel bar, with a bit of flat bar welded to the side of it, at 90 deg. You poke it under the tile, then rotate lifting the rear edge of the tile, to clear the hooks, moulded into the tile.
