Roof tile
it cracked he end off at 45 degrees so doesnt really help unless I take the full tile out, bit worried I may not get it back in again without a full tile at the ready I might do more damage
You might need a gadget, to lift the tile up enough to unhook it. I made a bit of flat steel bar, with a bit of flat bar welded to the side of it, at 90 deg. You poke it under the tile, then rotate lifting the rear edge of the tile, to clear the hooks, moulded into the tile.
I dont think you can buy just one tile or I would, dont want a pallet of them
Think on !!!!! [TM]
Its worth asking a maintenance guy from the local council if they have any spares lying about from when the house was built.
A long shot but you never know.
