If an extra pane of glass is put in with a large gap between it and the other panes, that should reduce the external noise. However, if trickle vents are put in for ventilation, some noise will get in as well.
I think you're right - there really isn't a simple way to have ventilation and noise reduction at the same time, so the simple solution really is to avoid trickle vents, and just open the window for a short period of time - this also gives you a chance to smugly appreciate the 'turning off' of external sound as you close the window.
There is a way to have Triple Glazing and ventilation ...Simple answer is dont have Trickle vents! Use a PIV or MHEV system instead, or use acoustic vents ( but they will still let a certain amount of noise in)
