Advice needed re paver grids and gravel edging construction etc
8 Jun 2013
Gloucestershire
Our property is adjacent to a railway line and subject to vibrations. The existing patio slabs have shifted and joints opened up over the years. Research has suggested putting down paver grids. Has anyone experience of installing these? Are they the same as gravel grids ie sitting on top of a fully compacted sub-base and then you sit the pavers on top or, are they made to the exact size of the slab which then slots into each 'pocket' in the grid, the grid being locked together?
My second query: we intend replacing one area run of pavers with turf and then a gravel edge, 6 inches wide maybe, alongside the wall. We'd put this in a grid to keep it in place. What would be the norm for size of gravel? My wife also suggested resin to keep it all in place. My worry is if the resin cracked it would look worse. Are there any negatives to having this gravel edge? I'm thinking, water run-off making the turf edge soggy.
What is the construction process please for putting down the edging and turf? I was thinking, turf to the wall and then cut back for the edging; install weed membrane then gravel-grid and then gravel and then pour over with the resin. Does this sound about right?
Pic shows where slabs and sub-base have been removed. Approx 800 wide
There is no norm for the size of gravel, you choose whatever appeals to you visually. Why do you think it needs to be in a grid or glued down? Have you considered corten steel edging between the grass and the gravel?
Hi. Thank you for taking the time to reply.
From a construction perspective, is it a requirement to have the gravel edging or is it just for aesthetics? In other words, could the turf simply butt up to the wall face?
With regards putting it in grids, it is really to stop the whole lot from shifting about. We're planning to do the same with the slabs. We get a lot of vibration from the railway and all of the joints in our current patio have opened up.
Would the gravel edging (say 6 inches wide) need to be put onto a compacted sub-base as one would do with placing slabs or can I just turf up to the wall then cut it back and place a weed membrane with steel edging?
Gravel edging is usually put against walls to reduce splash up the wall from rainfall [vs a flat surface]. I am not sure if it achieves this by stopping puddles forming, or because of the rounded surface.
You compact the base to make it flatter and more stable. It will give you a more even finish.
