Stiff tap
10 Jul 2021
Hi all
Our kitchen tap is really stiff to turn off and on leading to it dripping when not turned off fully.
I have removed the little cap on the handle but can’t work out how to unscrew whatever is inside and what’s needed to do that? Hoping once the handle is off I could give a good clean and it might smooth things out
Pics attached hopefully it’s visible
Thanks in advance
Can you see anything? Normally a small allen key required, either in there or below the longer rod if removable.
