Water hammer from unvented cylinder
Is that arrestor taken off the T before the ICG one of those tiny ones?, if so a 2/5L maybe set to 2bar might be better if you have the room to install it.
Yeah those ball ones - got any recommendations for a bigger one? All the ones I see online look like EV ones you'd use for an UV cylinder
Zilmet make 2L ones but they are quite expensive, maybe because they are stainless and can withstand 15bar pressure?
What isolator do you have on the mains cold to the UV?
Photo.
It's a gate valve.
BC is balanced cold back down toward rest of house taps
Yeah just had a look - be good to see if that would cure the problem before I commit to buying one! I'm surprised even the little one didn't quieten it even a bit!
You said in your other thread that the mains pressure spikes from its normal 4.5bar to 8.0bar during the water hammer, you also say that the shock seems to be close to or at the UVC PRV, if so, I would install a 2L shock arrester close to the PRV end or maybe even better, T off from the balanced cold further along before it tees off to any of the users, set it to 3.0bar.
Yeah just thought fitting a pressure reducing valve at the mains after the meter would help or at least lessen the noise! I don’t get the spikes anymore but still hammers.
Just can’t get why it’s bad so and doesn’t happen when it’s settled for a bit and only when the hot is flushed through
Hope your cylinder coil isn't like one of these .....
Those corrugated coils can trap air in the corrugations but I suppose shouldn't cause water hammer.
How old is the installation?
Looks quite old from the photos supplied! Hate gate valves.
3 years. New build is all I’ll say!!
Been doing it since the house was 6 months old. The builder kept saying it was due to a lack of service of the cylinder.
