How to use a crimp tool - uninsulated crimps
4 holes, the markings are not all in the same location relative to the holes.
Many thanks. That makes some sense, but only because of what you have drawn. I feel sure that I will not have been the only one struggling to work out how one was meant to use it - and I'm not convinced that I do even now that you have 'annotated' it !
It's a rather nasty piece anyway ....
I'm definitely inclined to agree with that!
Thanks again.
I have this type and its pretty obvious....small slot 10mm bigger slot 16mm :)
My large crimp pliers are of this design View attachment 416346 and one would need to be Charles Atlas to do 120 mm, and 10 mm, so easy not to be square on, in real terms 16 - 90 mm.
The Lidi ones never really used.
Yes I agree that type does get a bit hard, I also have another which will lay on the floor a bit easier to apply body weight.
When I was in BT I had a rather lovely hydraulic ratchet crimper with a whole raft of mostly hex crimp jaws, it was the only tool I had to hand back when I left. Oh what a comedown having to use other types.
Oh has it already been mooted? It has been a fair amount to read the whole thread in one go and some has been speed-read.
Not really 'mooted' as such - I have merely observed that, in comparison with 'obvious' ones I'm used to seeing, I'm not quite sure how one is meant to use that one (for particulatr sizes of crimp)!
I worked for Vickers Armstrong in the 70s, crimping tools were calibrated then as were torque wrenches
Was that in Barrow. On the subs or gun squad? They used to give us ratchet crimpers on the gun squad when doing panel wiring but can't remember anything being calibrated or labelled :LOL: :LOL:
