Tyre valve stem leak
He confirmed changing of valves when changing tyres. That makes him a more experienced expert than you.
The rubber valve stem hardens with age so it’s not really worth sodding about with. They should always be replaced whenever the tyre is taken off for repair or replacement.
#3 my first post in this thread. I guess you can’t read….
Keep digging.
Post #1 never said anything about a new stem being fitted. Carry on, you’ll soon get to 10 pages.
Post #1 stated new tyres from shop. You incorrectly inferred old valves. This shows you literally have no experience. You may be an "expert" in the class room, but you are a beginner in the real world.
Yep. New TYRES. No mention of valves. None. Zip. Zilch. Nada. You are even below the knowledge of a beginner.
I have a leak on one of the stems around the stem rubber.
I know this has been done to death, but how do you know? Soapy water bubble test?
I've always been sceptical about need for a new valve at each tyre change, just something to get a few more ££ out of you. Valve in rim should last the life of the car IMO, and if the core leaks it can be replaced. Years ago when I was short of cash I refused new valves, nowadays I can't be bothered and it looks a bit parsimonious, so I go along with it.
But my current car has tyre pressure sensors installed in the valves (works very well). Tyre fitters don't mention changing them, but I don't suppose the seal into the rim is any less likely to leak than conventional valves.
The valve has a chance of being disrupted/destroyed when contacting the tensioned bead during tyre mounting and dismounting.
So the new valve could be disrupted/destroyed when contacting the tensioned bead during tyre mounting?
:ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO:
