To be fair the OP does seem quite sure of himself, unlike some others.
The hallmark of a fool!
No doubt people think this is faffing. But, I think this is leisurely research.
The valve stem base for the play wheel is easily accessible. For my regular use wheel, the stem is deeper in. But, I don't think it will be a problem. The stem can't be rotated because the rubber has bound to the metal from heat cycling and ageing. The rubber feels sticky as a sign of aging. Synthetic rubber reverts back to crude oil over time. The valve base is positioned to interact with the tyre bead during mounting/dismounting and inflation.
your're not joking. The perishing and shine on that tyre makes it look about 7-10 years old!a sign of aging
You are as inexperienced as the others. The tyre is 22 year old.your're not joking. The perishing and shine on that tyre makes it look about 7-10 years old!
You are unable to prove you fitted one.Anyone, absolutely anyone who has fitted a tyre will know what I’m talking about.
What mug changes tyres by hand when they have a machine? I'm telling you now, you will never be able to change a tubeless car tyre by hand and if you by any small chance did, you’d do damage to either the tyre or the rim. When you eventually claim that you have done it, don’t forget to add pictures like I did, documenting how you did it so that others who come to this thread that also don’t want to take a tyre back back to the shop and get it done again for free, can see how you did it and what it cost. Should be good for a laugh.You would equate changing tyre by machine to changing by hand? What a beginner!
Excellent. Ask it if it remembers Tony BlairYou are as inexperienced as the others. The tyre is 22 year old
Blair personally stamped the date code on it!Excellent. Ask it if it remembers Tony Blair
I know you're just trolling, but earlier you said the reason you knew it was losing air was because it wasn't as round as it should be. Apart from that being nonsense, have you done any proper tests, like with soapy water, or immersion in a tank?If I didn't know it, why would I say it? I just don't do the obvious stuff. But for you, I'll do it just once. Yes, it is confirmed leaking there. Yes, I know what the valve core is. It is not leaking there. There is no leak major enough for me to see easily around the outside rim interface. There is no leak major enough for me to see easily on the rubber. The inner face of the wheel was not examined because it's kinda obvious no need to look there until the primary leak is sorted.
Not nonsense. Fully inflated shapes differently to partial inflated. May be my senses are just sharper. Nothing I can do for you. I took one look at tyre and knew shop playing with me. Naturally, confirmation steps were taken.I know you're just trolling, but earlier you said the reason you knew it was losing air was because it wasn't as round as it should be. Apart from that being nonsense, have you done any proper tests, like with soapy water, or immersion in a tank?
As usual, don't answer a question, just troll on.Not nonsense. Fully inflated shapes differently to partial inflated. May be my senses are just sharper. Nothing I can do for you. I took one look at tyre and knew shop playing with me. Naturally, confirmation steps were taken.
You said it yourself, why do you ask the question to death and expect a different answer?As usual, don't answer a question, just troll on.
