2 gang 2 way switch trouble
25 Aug 2014
Cheshire
Hello,
I’m current replacing the 1 and 2 gang switches at home with new faceplates.
I’ve come to replace the last one (floor 1 hall hallway) and had some problems. As I took the old switch off two wires were loose. One of the L2 blocks had the connector screw fall out as I removed it (starred in the pic) it looked like the wire came out of there.
I’ve rewired the original plate back as it looked to be (see attached).
The floor 1 light works fine (controlled from this switch and downstairs). However the floor 2 light doesn’t work from this switch and only works from the floor 2 switch if this switch is in the on position. I tried moving cable from the L2 starred position to join the other L2 red terminal but didn’t work either.
Before I call time and call an electrician is there something very obvious I can try?
I'm a DIYer, not a sparky.
Which 2 wires? the Red which is now in L2* and which other?
I'd be tempted to swap round the 2 Reds which are in the Floor 2 Light switch.
Do the new switches have metal faceplates? If so, you must make sure they're earthed (preferably direct from an incoming cable and then have a short flylead from the faceplate to the earth terminal in the backbox).
Thanks. The two loose wires were both reds which are in the L1s, the Red that is in the COM was definitely in there before, which is why im confused.
Yes very good point re earthing. Will make sure this is done if manage to get it sorted and swapped (original plastic faceplate is back on currently)
Just to clarify ,when you released the switch from the mounting box, 2 red wires were loose. You then removed all other wires from their terminals. Is that all correct ?
If so ,did you label all the wires so you could put them back into their respective terminals ?
It would appear that you have not ,and have mixed up the original connections .
It's confusing the way you're writing this as if it's one switch - I'm assuming from your description this is a 2 gang 2 way faceplate. If the problem you're having is with the right side switch, try swapping the 2 black cores.
If the left side switch is working correctly then don't touch it. These are 2 separate switches.
