Bosch washing machine cycle taking too long.
17 Nov 2011
London
Hi all, I have a Bosch wab24161gb/05 washing machine. It has started playing up in that. -,when you start it,let's say choose programme 57 min it's taking 3 hours to finish. Its stops on 1 min and continuously working like it's just started, when you press the button for speed then gives you another 40 minutes and after that finishing.
Any ideas what could be causing this?
Thanks in advance.
I would check the heating element for starters. The 1 left in the display is just a fault message.
Thanks in advance.
Check pump , it will never finish a cycle if blocked or not pumping .If it reaches 1 minute but repeatedly attempts to redistribute the clothes, an unbalanced load can prevent the final spin , unbalanced load can interfere with proper spinning/draining.
