How good is the charge function in solar cctvs?
28 Jun 2021
Hi
As per title: how good is the solar functioning in charging an outdoor CCTV similar to the one in photo attached? I read it needs 45 mins or so a day of sun to charge but we don't seethe sun sometimes for days, does this make the CCTV uselss for someone relying fully on solar energy to charge?
365 day battery life it claims. and if thats on a full charge, you will want it to get fully charged asap.
we wouldn't recommend wifi or solar but only way for you to know is to test one out
That's why the thread if someone here has experience with such product.
One manufacturer claims "powered by a 5200mAh battery that lasts up to 6 months on standby or 1.5–2 months with daily use. Add the optional solar panel and the camera can run indefinitely with sunlight—zero downtime, zero charging, zero hassle" .
Are ieGeek a well known recommended brand in this field?
I have a Reolink argus ptz camera, solar charged, it's never below 95% charge. The solar panel faces south, and camera is in a low traffic area so not many triggers throughout the day or night.
The main things about this is south facing and low traffic.
How long has it been in? Just had some warm dry weather this year, until last couple of days but even then had some sunny spells.
Ring CCTVs seems worth considering
Ring is an Amazon product, in terms of reviews, you may not be seeing the full picture.
I call to many homes where solar doorbells and solar cctv cameras aren’t working and WiFi is easier to compromise.
Seen some with solar panels were they have run cables to other parts of the building away from security device to get better charging
