Built 4 years ago, flat. Internal wall. Knocked it. Pretty sure friend said it was too. Aren't external and neighbour's wall all breeze blocks batoned and plasterboard and internal walls studs?How do you know it’s a stud wall?
But must be able to guess roughly where the stud is measuring the 16 or 22 inches (every stud) from corner?Looks wide enough so that it would fix somewhere along it's width into 2 studs.
Mark where he wants it to go on the wall then use a tiny drill bit and select several of the holes to locate the studs. Filling those that have no studs behind. Plus, shelf will also hide those filled holes.
My 6mm SDS drill is a bit bent, I guess get a new one?
