Garage wiring using Lidget Compton lining brackets
10 Jan 2016
Is there some way of installing wood battens (for wiring) to my concrete garage, so the battens are fitted into the recess between the pillars instead of onto the pillars?
Trying to avoid the wiring sticking out into the garage as little as possible. I don't want to glue the battens, or drill the concrete.
Can't tell anything from your pic or descritpion. Is it a prefab concrete. Will you be running cables verticarly and horiizontally. Do you just want to surface mount the cables on battens. How will you be fixing acessories
What are the battens for? you say "wiring", but what does that mean? They aren't wide enough for accessories.
I assume the panels already have some holes where the bracket* fixings go? Sunray's idea looks like a good un, or right-angle brackets?
* Small flat pieces of galvanised steel with 2 holes punched in them. £25 for 12. :oops:
