I bought but never used a 12V car solar panel charger so warranty is no longer valid.
Recently decided to set it up in the garage to charge spare 12v 40Ah lead acid car battery.
Connected it all up but have never been able to get it to actually charge the battery
Voltage from solar panel = 18+ vdc in hazy sun
Voltage at battery 11.8 volts after a few days usage but was always powerful enough to crank the engine
Thinking controller faulty bought a new one.
Same problem so thought I would bypass the controller, and read the same individual voltages before connecting solar panel to the batteery.
After direct connection of panel to the battery V drops to 11.3 V measured at the battery and doesn't go any higher.
Doide and polarity are ok.
Does this suggest panel is faulty and breaking down under load. Many thanks
