So the floor looks a bit tatty in the bathroom and is lined with part loft board, part ply and part chip board. Since I'm renewing the bathroom, I thought it maybe a good idea to pull everything out and refresh. The board appears to be 22.3mm thick.
so its a good clip for education but doesnt really explain much esle than using pinewood planks for subflooring? I dont mind using that if gives me a solid floor. My idea was to use 15mm marine ply and 6mm cement board on top then your final covering??
