Hi all,
I'm getting a reasonably intermittent burner lockout on the boiler (meaning every third or 4th ignition fails). I can see a strong spark across the electrodes, which are in good condition and position.
Following the fault diagnosis, the resistance across the brown and violet wires to the gas valve are both less than 100ohms (67 and 65), which leads to the diagnosis that the control board needs replacing. My question is that if it was the control board would it not be a constant fault, and not intermittent?
I just wanted a second opinion before I splash out on an expensive part.
Thanks.
JH
Thanks.
JH
