My Worcester 24CDi boiler has the ignition lockout problem when the heating comes on, tripping out after 10 seconds or so, and occasionally when the water is in use. The system is pressurised correctly. I've read a lot of the other posts but don't seem to have a definitive solution. Is it the circuit board or diverter valve?
From the manual:-
"IGNITION LOCKOUT
The appliance will enter a lockout condition in the event of the
burner failing to ignite.
If the burner fails to light within a preset time of 10 seconds the
electricity supply to the gas valve will be interrupted.
If ignition lockout has occurred, the central heating demand
indicator will flash slowly (approximately once per second).
The appliance can be reset by pressing the reset button and
holding in for 5 seconds. Check that the gas supply has not been
interrupted."
Cheers
Lee
From the manual:-
"IGNITION LOCKOUT
interrupted."
Cheers
Lee
