Connecting into a 3 inch soil pipe? Is there a fitting?
9 Apr 2006
Does anyone know where I can get fitting to connect into an existing 3 inch soil pipe?
I have seen the flange type ones for 4 inch where you drill the hole and then bolt it around. Where can I get a 3 inch version?
I think its a strap boss?
Thanks,
Just a thought here, but my house has a normal 4" stack, but above the highest connection it is reduced into a 3" for the vent pipe out of the roof.
The OP did say "Loft", so I reckon they might be trying to connect into the very top of the soil stack, currently used as a vent.
Thats exactly what mine is like. All 4 inch then with a 3 inch vent above the last toilet going up to the roof.
Was hoping that I could connect into this 3 inch pipe higher up, rather than running a sink/bath drain all the way down the void to the 4 inch section.
Any problems with that?
Any ideas where to get a 3 inch strap boss?
Thanks,
Local drain center stock 3" strap on boss. I fit them quite often. Got one to do tomorrow.
