I’ve a friend with a 98 ford escort with a over heating problem. I've taken the car for a spin and it heats up to shy of the red within a mile. If I remove and bridge the wire from the thermostat housing so the fan is on permanent the temperature gauge returns to a normal level quite quickly. I’ve removed the hose from the top of the radiator and turned the engine over and water pumps out, which suggest the pump is working????
After all this and plus checking the thermostat, changing the fan temp sensor, and flushing out/bleeding the cooling system it still overheats with out the bridging of the fan. Can anybody suggest a reason please?
