- Joined
- 13 Jul 2007
- Messages
- 118
- Reaction score
- 0
- Country
Right then, stripped the valve down and fortunately, I only needed to chip a little grout off rather than dig out tiles (phew) - all the seals and o-rings were perfect, although a little 'dry'.
I gave everyhing a liberal coating of grease and re-assembled it all.
Good news - before the fianl assembly, I tested and calibrated it and it works perfectly - red hot to ice cold in nice predictble and repeatable increments on the temp dial. Most pleased. Must just have been a sticking valve due to lack of grease? Anyway, works a treat.
Bad news - I can't get it to go back together properly. I know this sounds stupid, but I just dosen't feel right. My father is an engineer and my brother in law is also in engineering. They both helped me pull it appart again, inspect it all, check all the parts are as per the exploded diagram, all the seals and springs are seated, circlips in the right grooves, the washers in the right place, coponents in the correct orientation, etc, etc. Went though it with a fine tooth comb on several occasisions, but the temp control seems eccentric as if the shaft is bent, it feels tight and rough, rther than smooth and precise. It wobbles a bit and the final temp control knob won't seat correctly.
We checked and double checked everything using logic and process.
So it now works, but feels like a cheap B&Q value valve, as when it didn't work, it felt like the volume control knob on a very expensive hi-fi amp if that makes sense.
So, after 6 hours of messing and much frustration with the 'closed on weekends no help line', I've left it semi assembled in disgust and will phone them tommorrow and tell them my woes.
Not sure what they'll say, but it comes with a 10 year guarentee and although in a semi stripped state will mix the water well, it won't now fully assemble. I tried their strip and rebuild kit, but it hasn't worked (properly) so as said before, they'll have to send out an engineer to have a look.
I'm certainly not going to dig out the rest of the housing and un-do all the compression joints etc just to send it back. If needed, they can send me a new inner asssey instead.
I'll let you know how I get on.
CH is still good as gols by the way, although I still need to replace the honeywell.
