- Joined
- 13 Jul 2007
- Messages
- 118
- Reaction score
- 0
- Country
Please help...
My wife is doing the 'told you so' dance around the living room because I ignored her request for an electric shower in preference for a faster flowing mixer that I've just spend a fortune on.
Problem is that unless the heating has been on for ages (hours) the hot water in the hot water cylinder seems not hot enough to supply the shower with enough temp to mix with the min amount of cold it must use to function to give enough temp.
It is a 'Hudson Reed 'Lowry' Thermo Mixer' fed with twin 22m pipe from a 1.5 bar pump on a grav fed system. All the locations and head height specs are well within guidlines. Water pressure is good.
Using a pyrometer I've measured the water out of the hot tap at 148F/64C which I understand is max as per regs? Anyhow, it works fine under these conditions.
However, after the kids have had a bath, the temp goes down to 100F/38C whcich gives a tepid shower at best, even when it is on full heat. I guess this is because being a thermo mixer valve, it won't fully switch off the cold if the hot isn't hot enough to give the desired temp, as this would cause pump problems, so therefore the min amount of cold it must let through is dropping the temp too much?
Tonight, after the kid's single bath, I uthe heating on for 1 hour, my wife had a shower and on full heat it was tepid!!!!
Angry 'told you so' wife....
Please help.
Why is the water in my cylinder only 100F after just one bath despite then putting the heating on for 1 hour?
Anyone else got a mixer that needs 148F 24/7 to get a decent shower?
Surely I haven't got to run the heating for hours and hours (£££££) just to have an on demand shower?
Please help.
