The boiler fires up but shuts down after a few minutes.
Therefore, radiators do not heat up.
I have a tank upstairs with a grundfos 15-50 pump next to it and a honeywell valve?(silver metal box with an arm on it) above that.
This morning I turned the speed dial on the pump to its highest position and the pump came to life and the rads heated up for about 20 minutes before the boiler shut down again.
When I checked the pump I couldn't hear anything and there was no buzz/vibration so I assume it stopped.
Took off the large screw nut on the front of the pump and nothing was moving inside.
So, is it that the pump has had it or is it something else that is stopping the whole lot working.
