S
sturharv
Struggling to get a safety discharge out of a property, are there any 'mains pressure' cylinders out there that don't require a discharge pipe? Think DPS do one but not sure
To
meet the requirements of the Regulation, installation of an unvented system
should be undertaken by a “competent installer”.
All installations of unvented hot water storage systems having a capacity of
more than 15 litres should be notified to the relevant Local Authority by
means of building notice or by the submission of full plans. It is important to
note that it is a criminal offense to install an unvented hot water storage
system without notifying the Local Authority. The installation of the unvented
cylinder and hot water system must comply with BS 6700 and the HSE
Legionella Code of Practice.
Where did you get this nonsense from ?.
They could at least get the spelling correct if their going to use that kind of language and criminalize people for installing a hot water system.
"It is a legal requirement that the local authority Building Control Officer be notified"
My understanding of the wording is ..."It is a legal requirement that the local authority Building Control Officer be notified"
When did it change to "criminal offence" ?. I suspect it is an over zealous local authority that has added this stronger term.
If the UHWC is near the bathroom you can discharge through a dry trap and suitable solvent waste, but must enter suitable stack too!
