405 immobiliser problem
23 Jan 2008
Sussex
pls help have a 405 gtd with the immobiliser stuck on. have changed battery on key fob and tried jump starting but no joy. can anyone help?
car is an L reg with factory fitted alarm system
Have you tried inserting key in ignition turning it to position 1 then pressing the fob button?
A similar method is used to re-synchronise BMW key fobs.
Wotan
For some reason I seem to remember there is a master switch somewhere either in the engine bay or in the boot. You can then disable the immobiliser that way.
Do you have the pin number keypad in the box between the seats?
If so then the ribbon cable was a favourite to fail !
You MIGHT get it to start if you power the fuel solenoid seperately directly off the battery if you need to move it.
Tony
If not then I would have expected the alarm to be sounding???
If it does not respond to the IR key fob code then there is a very simple operation but I cannot publically post it otherwise Mad Mod 10 will delete it as "inappropriate security advice" !!!
Tony
