Fitting bathroom extractor fan
30 Jan 2008
Lincolnshire
Hi I wonder if someone can help me my bathroom extractor fan recently stopped working so I bought a new one a emcovent EVSLIM4T with timer - the old extractor did not have a timer.
The thing is I do not know which wires go to which
the wiring from the house to the fan are as follows
2 black wires (I take it these are neutral)
1 red wire (Live)
The wiring on the new fan terminal block are as follows
1 brown (live)
1 blue (neutral)
1 black (T) I think the t must be timer?
What I want to know is which wires go to which so I can connect the fan up or if the wires that I do have are not correct then I take it I will need to call for an electrician - I would like to avoid this if I can because I feel it may be a tad costly just for connecting up 3 wires!
I think it may be the case that I need 2 live and I only have one, but I am only guessing
Any help is much appreciated
How was the old fan connected?
Were the two black wires together in the same terminal?
Any electrical work undertaken in a bathroom must be carried out by an electrician. It is a stipulation of Part P.
You don't have to be an electrican.
Any DIY'er can carry out electrical work in their own homes but work carried out must comply with Part P requirements, including prior notification depending of work being carried out.
Yes the old fan had 2 black wires in the terminal
Did the old fan used to come on and off with the light in the bathroom?
If so then it's as you thought, you need a permanent live for the timing circuit.
Yes the old fan came on with the light -so it will be an electrician I will need to fit it correctly.
Or I could buy a new fan without a timer - it will work out cheaper!
By prior notification do you mean contacting LABC?
This would incur a charge out of all proportion to the scale of the job.
